F23 Swap Guide
Out Now!
suspendedhatch@gmail.com
OEM Cruise Control Swap
This is how you swap factory cruise control into a 92-95 Civic or 90-01 Integra that came without it. The 92-95 Civic and 94-01 Integra parts are all interchangeable.
All of the factory cruise control wiring is entagled in the SRS harness and the interior harness. Cars w/out cruise control have none of this wiring and it's impractical to swap the entire harnesses. Tinkering with the SRS harness can be dangerous. This how-to shows you how to wire it all from scratch.
component diagram
Reader Contributions
Fan feedback inspired me to finish it and revise some of the info. Big thanks to Blair Dillman from Rochester NY, Photobucket. A second contributor wishes to remain anonymous. C.A. provided some helpful feedback leading to clarifications. Keep it coming, folks!
How It Works
Some cruise control systems operate by vacuum. Some are connected to the throttle body with a cable. In this case, Honda connected the actuator cable to the gas pedal. A small ECU in the driver's kick monitors the vehicle speed sensor, as well as the tach input from the distributor coil. A master switch enables the whole system, while steering wheel mounted controls allow the driver to select the speed to maintain. And finally, there are inputs from the brake pedal and clutch pedal to disable the system whenever either pedal is pressed. All of this is independent of the Engine Control Unit.
cruise and non cruise pedal assemblies compared
Models that came w/out cruise control lack the bracket on the throttle that the actuator cable connects to. Also, the switch on the brake pedal has four pins instead of just two. The throttle and brake are one whole assembly connected to the brake booster. There also is a lack of any wire harnesses for the cruise control system. The OEM steering wheel has no provision to mount the control switch. The dash has a blank panel that can be removed so that the cruise master switch can drop right in.
Helms Manual
These are the pages (pdf) in the Helms manual that cover cruise control.
Parts Required
These are the parts you need to get from a cruise control equipped vehicle. Make sure you get the hardware for the parts shown and get both sides of each wire harness. You have to cut the plugs off from the dash harness so make sure to get as much length as you can.
cruise control actuator
Cruise Actuator
auto cruise ecu
Auto Cruise Module
Integra and Civic modules are interchangeable even though a sticker on the module specifies an ECU code.
cruise module bracket
Module Bracket
cruise control master switch
Cruise Switch
Resume Accel, Set Decel Switch
Resume/Accel, Set/Decel Switch or aftermarket off-on-off momentary rocker switch.
throttle and brake pedal assembly
Gas and Brake Pedal Assembly
Note that I forgot the four pin brake switch harness and had to go back for it later.
combination throttle cable, cruise cable bracket
Throttle Cable/Cruise Cable Combo Bracket
clutch cruise switch
Some models lack the lower clutch cruise control switch so check if you need one.
Cable Reel
Cable Reel and yellow plug connector from steering column. You need the lt grn/black and lt grn/red wires de-pinned from this harness.
instrument cluster
If you have a non-tach instrument cluster and you want the cruise indicator light, you'll need an EX/LX/Si cluster and the little green harness that plugs into it.
Installation
Mounting the components is easy. The only physically difficult task is swapping the gas/brake pedal assembly.
Swap Pedal Assemblies
Drop the Steering Column
To get the pedal assembly out, it's necessary to drop the steering column. You don't have to completely remove it, so don't take out the pinch bolts at the rack. Remove the clips and the black cover.
center column bolts outer column bolts drop the column
Remove the two inside bolts first, then remove the outer bolts while supporting the wheel. Carefully lower it to the floor.
Remove the Pedal Assembly
First remove the pin that connects the brake pedal to the master cylinder. There is a tiny cotter pin that you need to remove before you can push the joint pin out.
Remove the two 12mm bolts. One is just above the throttle, and the other is above the column holding the brake pedal bracket. Then remove the four nuts above the brake pedal that hold the brake booster. On the engine bay side, pull the brake booster forward until everything clears the firewall. Use a bungee cord or something to hold it in place.
Next disconnect the throttle cable from the throttle body. It isn't necessary to remove the bracket holding the sleeve, we just want some slack on the cable itself so we can disconnect it on the gas pedal side.
rotate out the pedal assembly
(Ignore the fact that the column is still bolted up in this pic.) Pull the pedal assembly forward and down. The brake switch will get hung up on the ignition wire harness so you will have to fight with it a bit. Now that they're more accessible, you can pop the tab out that connects the throttle cable to the pedal, and push in the pin and release the brake switch harness. Rotate the assembly as you lift the column so that you can get enough clearance to pull it out.
Put everything back together making sure that the throttle, brakes, and brake lights are all working properly.
Cruise Actuator
Before you run the cable through the firewall you should test the unit. You need to have access to the cable to test the actuator.
cruise actuator test
Remove the two 10mm screws holding the cover on.
distributer ignition power
Pull the actuator side of the pins out of the harness. Temporarily ground the black wire.
You'll need power to complete the test. I found it convenient to pull one of the leads out of my digital voltmeter, unplug the two-pin distributer harness, and shove the lead in the blk/yel pin. Put the key in the ignition and turn it to the third position (Key On, Engine Off).
Firewall Side Actuator Side
blk blk
brn/blk blu
brn brn
brn/wh wh
Test One
Ground black and touch power to white. You should hear the actuator lock so you can't pull the cable.
Test Two
Ground black and blue. Touch power to brown. The actuator should push the cable out.
Test Three
Ground black and brown. Pull on the cable so the linkage is in a middle position. Touch power to blue. The actuator should pull the cable in.
The first actuator I got wouldn't move the cable. The motor inside the actuator was bad, though I could hear it click.
Cruise Actuator Installed firewall grommet for cruise cable
If the actuator is good, mount it to the pre-existing holes in the frame and run the cable through the bracket and through the firewall. Then connect it to the throttle pedal under the dash.
Cable Bracket
cable bracket installed
Auto Cruise Module
auto cruise ecu mounted
Installing the bracket for the cruise module is difficult because the dash harness is in the way of the 10mm bolt that is already highly inacessible. First install the bracket, and then install the module. Have fun.
Cruise Switch
master switch installed
Leave the switch out until you've wired it up. Pop out the combo switch assembly by pushing from behind. Unplug the dimmer harness, then push the four clips simultaneously to release the blank panel where the Cruise Master Switch drops in.
Thanks once again to Blair Dillman for the following contribution!
OEM Switch
airbag short connector
Unscrew the flap on the underside of the steering wheel, unplug the SRS harness, and plug this short connector into the airbag side. Installers have been killed by airbags so don't take this lightly.
T30 torx screws
Use a panel popping tool to remove the covers on each side of the steering wheel to expose the T30 screws.
airbag removed back of airbag
Once you have the T30's out, you can remove the airbag. Put it under the car where it can't kill anyone. Or stick it under a dumpster and set it off (shenanigans).
steering wheel removed
Center the steering wheel. Remove the 19mm socket and pull the wheel. Remove the screws and pull the cable reel straight off.
cable reel replaced
Swap your non-cruise cable reel with the donor cable reel. Make sure yellow alignment notch is centered and cable reel is set to top center before reinstalling wheel.
Resume Set Accel Decel Switch mounted
Reattach the steering wheel and connect the cruise switch.
RA/SD switch finished
Aftermarket Switch
A fan of the site kindly contributed photos and a description of how to use an aftermarket switch. This is useful for people that have an aftermarket steering wheel.
"After pulling the OEM S-D/R-A switch apart to make the modifications detailed in the ‘Cause for Alarm’ website, I realized there was a cleaner way. All the switch does is route a +12v power signal to the cruise module where it determines, based on it’s current state, whether to set the speed, decelerate, accelerate, or resume the last speed selected. A simple (off)-on-(off) momentary rocker switch would work just as well and could be placed anywhere in the vehicle. I wanted to put the switch in the blank next to the dash light dimmer so I chose a micro-sized switch from www.wiringproducts.com. The switch + shipping was less than $9. If you have a decent electronics store nearby you could have it for just a few bucks. Unfortunately Radio Shack did not carry what I needed. The switch fits perfectly in the hollowed out blank. The cut-out is .5”x.75”."
sM sunroof switch blank sM hollow out the back side sM cut a rectangle hole sM new switch
"Notice the rocker is in the middle. Pushing it to one side or the other sends power to that side. I wired it like the OEM switches; down is set/decel, up is resume/accel. The rocker is spring loaded to return to the middle. Switch is part #7500007 in case you can’t read it."
sM mount the switch
"Not the straightest or most centered but hey, it works! Note the mirror switch. I got that done from your site too!"
Once again, thank you Mr Anonymous fan of the site and congratulations on being the first person to follow through on their promise to contribute content!
Wiring
There is a lot of wiring involved. Most of them are wired together, effectively cutting the amount of wires in half. Only a few go to the vehicle.
Cruise Switch
main switch wired to dimmer
Three of the five wires found on the main switch can be wired color-for-color to the dimmer switch right next to it. The other two have to be extended. The two blk/yel wires connect to the under-dash fuse box blk/yel. The lt grn wire extends to the lt grn on the Auto Cruise Module and to the lt grn on the Brake Switch.
If you are swapping to a cruise cluster and want to wire the Cruise Indicator light, then wire it at the same time as the Cruise Switch.
Behind Cluster (VSS, Tach, Cruise Light)
Several connections can be made behind the cluster. The tach input is solid blue D5, and the Vehicle Speed Sensor is yel/blu D11.
To use the gauge cluster Cruise Indicator light you have to swap in a cluster from a Civic that came with Cruise Control (EX, LX, Si). If you have one of the rare VX or EX clusters with the shift light, then this plug harness is being used for that purpose (pink wire). You can wire up a separate light or just live w/out it.
Three of the Cruise Indicator light harness wires go to the Main Cruise Switch. Yellow goes to Blk/Yel, Red/Blk goes to Red/Blk, and Black goes to Black. The Red/Blu wires goes to Red/Blu on the Auto Cruise Module.
Brake Switch
brake switch diagram
It's easiest to re-pin your brake harness to the four pin harness before the pedal assembly is mounted. B and C in the above diagram goes to B and C on the four pin harness. There are two light green wires on one pin on the four pin harness. One branch goes to the module, the other goes to the Main Switch. Gray goes to the gray on the module. Branch off the grn/wh wire and run it to the grn/wh on the module.
Clutch Switch
The pink wire on the Auto Cruise Module goes to the pi/blk wire on the lower clutch switch.
Under-Dash Fuse Box
fuse box diagram
The blk/yel's from the Auto Cruise Module and the Cruise switch can be joined to the blk/yel wire in the top left of the gray plug on the under-dash fuse box.
Cruise Actuator
The Cruise Control Actuator has four wires. One goes to chassis ground via a ring terminal. The other three run into the passenger compartment and are wired color for color to the Auto Cruise Module.
cruise actuator ground
Crimp a ring terminal onto the black wire and ground it at the 10mm bolt shown here.
Resume/Accel Set/Decel Switch
RA/SD wiring
De-pin the lt grn/blk and lt grn/red wires from the yellow connector that came from the steering column on the donor car, wire them to your Auto Cruise Module, and pin them into the empty slots on your car's connector. DO NOT mess with the other two wires. One is for the horn and the other triggers the airbag.
Auto Cruise Module
Wire Color Connects To
Brn/Wh Cruise Actuator Brn/Wh
Gray Brake Switch Gray
Black Ground Chassis
Grn/Wh Brake Switch Grn/Wh
Lt Grn/Red Set/Decel Button Lt Grn/Red
Lt Grn/Blk Resume/Accel Button Lt Grn/Blk
Blue Tach Behind Cluster Blue
Brown Cruise Actuator Brown
Red/Blu Cruise Indicator Light Behind Cluster Red/Blue
Brn/Blk Cruise Actuator Brn/Blk
Blk/Yel Fuse Box Blk/Yel
Yel/Blu VSS Behind Cluster Yel/Blu
Lt Grn Cruise Switch AND Brake Switch Lt Grn
Pink Lower Clutch Switch Pi/Blk
Cruise Switch
Lt Grn Auto Cruise Module Lt Grn
Black Dimmer Switch Black
Red/Blk Dimmer Switch Red/Blk
Red Dimmer Switch Red
Cruise Indicator Light (optional)
Yellow Fuse Box Blk/Yel
Empty
Black Dimmer & Cruise Switch Black
Red/Blk Dimmer & Cruise Switch Red/Blk
Red/Blu Auto Cruise Module Red/Blu
Cruise Actuator
Brn/Blk Auto Cruise Module Brn/Blk
Brown Auto Cruise Module Brown
Brn/Wh Auto Cruise Module Brn/Wh
Finishing Up
mess of wires heat shrink tubing bundled wires harness soldered on finished
Testing Auto Cruise Module Harness
test wires
Continuity to Ground
To test for continuity to ground, set the meter to continuity. Put the black probe of your multimeter in the door pin or the key cylinder to ground it, and the red probe to the circuit you're testing. Most meters will make a tone.
Battery Voltage
Set the meter to 20V DC. Put the red probe on the wire and ground the black probe. The meter should show about 12V. The same reading as if you put the red meter directly to the battery's positive post and the black meter to the negative.
Ground a Wire
Take a piece of spare wire, strip each end. Ground one side to the chassis and put the other end on the wire. Never put ground to any wire with a yellow harness plug or in yellow split loom. These are the SRS wires, and if you ground one, it could deploy the airbag and kill you.
Put Power to a Wire
Never put power straight to a wire w/out a fuse. Get an inline fuse holder, strip each end, and insert a low amp fuse. 7.5A are pretty easy to find. The far left option output on the under-dash fuse box is a convenient constant 12V.
Helms Manual Errors
The Helms Manual has several errors in the wiring diagrams and written information. It's not exclusive to the cruise control info- I find them all the time. I'll list what I noticed in case anyone is using the Helms to troubleshoot.
