- Wed Oct 15, 2008 8:02 pm
#74444
Josiah wrote:what happens if i dont wire the iab and the knoc sensor? im getting a skunk2 intakemani, i dont like the iab. and where are the iab and the sensor wires start. arent they vacuum? is minime and a bseries swap with vtec the have the same ecu pinout?
Well if your getting a Skunk2 intake mani then you won't need the IAB so you can scrap that. Click on the link below for wiring and etc.
http://www.c-speedracing.com/howto/b18cswap/swap.php
Regarding the pinouts, all depends on what ECU you will be using, if it's an OBD1 ecu you'll find the pinout diagrams on the link below
http://technet.ff-squad.com/wiring.obd1.htm
Try using google dude, there's massive resources on what your trying to do, HT is one massive directory which will answer the questions you have, it's a good learning curve for you too.
all the best
