By KRYSTED9354
#70256 ok, what was the EXACT name that the ac mount is called,
was it Torque mount , the one that connect to your ac bracket ?
I searched and cant find one to buy no were, and honda is a bit more then what i want to pay for the mount, any input ?
#70377 try looking things up on www.hondaautomotiveparts.com
it is the same database that dealers use.
http://www.hondaautomotiveparts.com/aut ... NDENSER%29
look at #12 & #13 in the diagram in the link :thumb:
By marvinp8700
#70385 i think it is called a torque mount
By suspendedHatch
#70471 It's just called a driver's side front lower engine mount. The metal bracket and rubber are one piece.
http://cgi.ebay.com/ebaymotors/Westar-E ... 0086273454
I suggest you get poly motor mount inserts instead. If you just do the two front lower mounts it doesn't increase vibration but it prevents the motor from moving so much when you shift.
