- Mon Oct 02, 2006 1:57 am
#45
This is an easy mod, cheap too!
Solid Motor Mounts = less engine movement. Solid mounts WILL carry more engine vibration to the rest of the chassis.
1. Remove your motor mounts (after you pot blocks or something under the engine to support it) The rear mount is a huge PITA to remove, if you only remove the side mounts you will still see a big difference!
2. Clean the rubber area of the mounts with a toothbrush and degreaser.
3. You'll be setting the mount on it's side to fill it up, so tape the back off to hold the urethane in.
4. Fill it up! Let it sit for a few hrs before moving, let it sit for a day before you use it in your car.
some pics:
Price: $12
some pics:
Price: $12
