By sqsi
#20148 That sounddeadenershowdown.com is a great writeup, I have recommeded that to a lot of people. I used Dynamat Extreme, Extreme Liner, TacMat, and Dyna Xorb in mine and it's pretty quiet now. Keep in mind I did so much because I compete in car audio sound quality competitions so it had to be done right if I wanted to win.
Lots of Dynamat sound deadener. about 3 bulk kits.
0 gauge power wire
Dynamat on the doors and put in the Diamond Audio Hex Mid
By chnzgoofball
#20154 ^^^^^ that is a shit load of dynomat!!! :o :o
By sqsi
#20167
chnzgoofball wrote:^^^^^ that is a shit load of dynomat!!! :o :o
You're not kidding, I spent alot of time doing this and there are 2 more layers on the doors now too
By Split_second
#31814 i just bump my music louder :D
By sqsi
#37308
ilmcrx wrote:http://www.partsexpress.com/tech/268-010.html
^^^ shows the how to and helped me tons
Not bad, but no need to use heat with Dynamat Extreme
By civic_man09
#57344 :thumb: yeah dynamat is awsome for deadening sound,,,,but its heavy..or atleast the stuff ive seen put in is..
By biretsu89
#57766 I want to try the dynomat or whatever.. but I also read about this stuff called quiet car solution. Its fairly new, so there is not many reviews on it, but I guess it works better than any padded sound quieter thing and its extremely light compared to everything else. Its a paste that you paint on to the inner wheel wells and under the car ect... look into it... I've read nothing but good reviews on it...
By civic_man09
#57799 hmmm...yeah ill look into that stuff...that'd be sweet if it was a lot lighter than dynamat and just as good
By biretsu89
#57821 Image
QuietCar® is a viscoelastic sound-deadening compound formulated especially for vehicle applications.
A quiet vehicle is a key sales point for all new cars.
QuietCar is designed to reduce weight, simplify assembly and lower production line time and used by vehicle manufacturers worldwide.
Features:
Provides damping to reduce noise vibration
Can provide up to a 20dB reduction of noise in certain vehicles
Adds stiffness to metal body parts increasing loss factor and shifting annoying frequencies
Reduces production line labor and part numbers
Can be applied in a consistent and repeatable manner
Available for OEM’s in 50 gallon drums and 250 gallon totes
Reduces vehicle weight
May be applied anywhere on body, and may be tuned for different thicknesses depending on desired result
Ultra-low VOC and HAPS compliant
No PVC’s
So yeah... Also.. look up some reviews on other forums.... good luck!!! Oh.. and its cheaper than dynomat
http://www.quietsolution.com/html/quietcar.html :thumb:
By civic_man09
#58043 that stuff is awsome :thumb:
By yashep
#58054
civic_man09 wrote:that stuff is awsome :thumb:
Have you tried it? cause it sure sounds good.
By civic_man09
#58057 nope...ive never even heard of that stuff
By Vincentex3
#87621 I Dont Know much About reducing noise but my bro softened his suspension a bit and got new wheels and now his car not only sounds quieter it feels nicer to. :thumb: : :?
