- Fri May 23, 2008 12:54 am
#56378
wait wait..what did you order graham? a 23mm swaybar ? The 23mm swaybar bolts for the d brackets sit much further away preventing the 13mm brackets holes to line up properly.
alot of the d bracket parts do not apply to the 23mm like the metal piece. that bolts to the subframe..
i would go with this setup..
http://www.beaksproducts.com/Products.htm
since you have most pieces, you can piece out what you don't have included in the EG sway bar drop in kit.
Graham wrote:Yeah i ordered up all the bolts and brackets from Honda so in theory i have everything to fit it now, but im not going to fit it if there's a chance it will damage my subframe
