By wozrally
#54176 hey new to the forums. i was wondering if the d15b7 ecu and the d15b8 ecu were the same. or if it wouldnt have to changed when swapped from motor to motor
By suspendedHatch
#54225
teal_dx wrote:I would switch ECU's :thumb:
Most definately. Get yourself a P06.
By wozrally
#54288 yeah from what i hear too is the ecu wont really know i got two more valves? idk sounds funny
but yeah i figures the fuel maps would be different.
now i would be able use the same harness correct?
By suspendedHatch
#54420 Fuel and ignition tables are probably very different. Download Crome, find some stock calibrations, and compare the maps. That's what I did when I was comparing the P07 to the P28.
All the plug harnesses are the same within an OBD generation. They'll plug in, and they'll run, but depending on different models there are a few different pins here and there ie EGR, LAF, shift light, VTEC etc. None of that applies to you I believe.
By wozrally
#54432 awesome thanks man! :woot:
yeah both basic motors jus one with 16 valves an ps and ac in a nutshell
