By oscar m
#25289 ok i have a b15b7.....i wanna knoe if the tranny and other stuff will fit it......can it? the only i change is the ecu and wiring right?
oscar m wrote:ok since i have the d15b7 on a 93 civic coupe........if i buy d15 vtec.......is everything the same like the tranny?wires?ecu?engine mounts? and lil things..
tranny yes, wires for the most part, ecu no, engine mounts yes, youll have to wire your car for vtec. its really not hard at all
By oscar m
#25292 ok soo everything i can use from the old stock motor right? wuts the only things i really have to change?
#25293 basicaly you could do a mini me swap
#25294 you'll have to run 2 wires to your ECU and 1 ground wire.
Using a P28, you'll have to do the same wiring that you would for a Mini-me swap.
There's wiring details in the mini-me swap thread:
http://civic-eg.com/viewtopic.php?t=10
By oscar m
#25296 mini me swap is a simple not really good work right? na but wriring and ecu thats the only i have to really change right other than that,nothing else right?
oscar m wrote:mini me swap is a simple not really good work right?
oscar m wrote: na but wriring and ecu thats the only i have to really change right other than that,nothing else right?
right everything else should bolt up
By oscar m
#25299 i'm kind of new on the d-series swap hahah..........ok wut about the d16y...., the zc and b15....which is better to swap a sohc swap?
By chnzgoofball
#25304 im guessing 95% of d-series are all interchangable...
By oscar m
#25306 daily drive since i'm in college......i jus love speed.....not to race but if i do in the track....but so d16y8, the only thing i change is the wiring right?
#25334 If you are putting a D16y8 in a 92-95 civic, you will need the engine harness from a OBD1 sohc vtec, Dizzy from a 92-95 DX and a P28 ecu. That way you will keep OBD1 and still run good.
I used to have this motor in my 93 Si.
#25339 Get your self I have had both the D16z6(boosted) stock internals, it was fun and the kit and all the tuning was like 1500! And now i have a jdm DOHC ZC and i LOVED it, it just felt good, nice hp and tq for a DD, so maybe a jdm DOHC ZC, and there like $750 with a tranny!
