By krunch
#161780 hi,
i got a eg (hatch) sat on 16 inch wheels, 215,45,16. in much need of lowering but i dont want it to be scrubing alllll the time but i do want to be low as i can go with out doing damage :D anyone else that has been in this situation input will be greatly appreciated.
THANKS! :thumb:
#161790 Do you know the offset of your wheels? It will make a huge difference. Also what is the width?
Camber can also help with clearance .
215 is a little wider than average for our cars, so you'll rub easier than if you had the normal 205.
By krunch
#161949 ye they are a bit wider then i wanted got them off ebay, advert said they were 205's till i picked them up and said are they f..... they're multi fits as well so not too bad but think i want to change them for the honda fat 5's 14 or `15 inch.
not sure of the offset, du know how i can find it out for 100+ alloy wheels?? cheeeeerzzzzz!!! :thumb:
By krunch
#161951 i found my wheels on http://www.rimstock.co.uk/rimstockuk/wheelrange.php
it gives a table of:
Size Offset
6.5 x 15 e+38/45
7.0 x 16 e+38/45
7.0 x 17 e+38/45
7.5 x 18 e+37/45
7.5 x 20 e+37/45
i have 16 inch so i guess its 7.0 x 16 e+38/45
