ECU, Wiring, Sensors
By parisp91
#157976 I popped a wire for my harness on my new motor (d15) Im replacing it but im stuck at the fuel rail.....im Having a Problem removing the four pieces that run with the harness...i kno there is a right way to remove these so sum1 holla at me sit sum advice...its probably the most simplest sh*t but im not tryna break anything else.....
By parisp91
#157986 I popped a wire for my harness on my new motor (d15) Im replacing it but im stuck at the fuel rail.....im Having a Problem removing the four pieces that run with the harness...i kno there is a right way to remove these so sum1 holla at me sit sum advice...its probably the most simplest sh*t but im not tryna break anything else.....HELP.
