- Tue Oct 06, 2009 5:52 am
#149088
Picked the car up few months back for $500 1995 Ex coupe with a sohc vtec 80k no rust car was real clean and is sitting on koni yellow struts with ground control springs..
Since then i have pulled the sohc started to clean up the bay doing a headlight harness tuck then going to shave it and start building a nice LS-v setup on the side, have also put in Blox LCA'S, ASR Subframe brace w. sway bar (no pics yet), also put on a Greddy SP2, Black housing headlights w. amber corners, Yellow fogs, Rear diffuser, 50/50 tails, few other things here and there finally getting motivated to get this project done.! lmk what you think so far will get some updated pics asap..
These holes will have patchs made and welded in when i end up shaving the bay.. im not going crazy with the firewall im going to keep the brake lines etc alone, washer fluid holder will be moved.
