#136101 ok some you know that i have this problem with my car
for some reason it was loosin all its power aftre it warmed up
and it would bog down and i was gettin real shitty gas mileage
well i unpluged my o2 sensor and the car ran great due to it runnin rich
and still have shitty gas mileage cause it spitin it out the exhaust
so my o2 is PLUGED in my car runs normal in OPEN LOOP and as the car heats up it goes into CLOSED LOOP my car runs really lean, which it suppsoed to run rich-lean-rich-lean..so on,
but when my o2 is UNPLUGED my car runs real rich
and it stayes rich throught out both open and closed loop
my question to ya'll is,
is this my o2 or is it somethin else
i dont wanna replace it and have this same problem thats why im askin :thumb:
thanks
#136121 ya i got a buddy wit a 93 dx sedan
ima ask him, i never thought of that
#136426 well its down to 3 thngs tht could be wrong wit my car
1. map sensor is bad and makin the car run lean
2. i got a bad injector(s)
3. my o2 is shot
but im to the pt were i wanna burn this shit outta this pos
:x
#136477 im gettin one monday
but i was talkin wit my teacher
[i got to UTI mechainc school]
and he told me its one of the 3
so today ima take out the injectors and check them out
make sure there isnt anything in the screens and makse sure
that there all there..lol
and also take out my map and clean it up a lil
#136938 well i cleaned my injectors and the ports where the injectors sit in the intake manifold
and now i have the famous honda surge
only when i hit my closed loop (op. temp)
my iacv is lil under a yr old
the coolent is full
so what do you guys think the prob could be
#136946 so the original problem is fixed but now your idle is bouncing? vacuum leak maybe? It is something that you recently did or changed... could you have damaged the MAP when you cleaned it?
#136948 problem fixed
my dumbass did hook up a vacuum line
from the fuel rail to the intake mani
#137436 ughhhhhhhhhhh
im bout to blow my car up
it still runnin rich
i have no CEL
nothin
:x :x :x
#137484 no the guy that i was gonna get it from forgot
but do you think it could be tellin it to run rich
By BLaCkSiLo
#137488
94_jdm_ferio wrote:no the guy that i was gonna get it from forgot
well yeah, it's kinda the main component to the AFR's and having a bum o2 can throw off your ecu without throwing a CEL... so i would definitely start there, i know they ain't cheap, my bosch was like $100
#137490 ok ima tell that dude i need that o2 hopefully he remebers
but wat makes a o2 go bad?
