By 95civiceg
#127368 DOES ANY HAVE A PICTURE OF A VACUUM DIAGRAM
my car has vacuum leaks and i dont where to start
#127371 mist the around the intake manifold with some water or carb cleaner, u can see where it coming from..
By 95civiceg
#132037 i tried the mist thing but i didnt see anything
any one with pictures
#132044 when you misted around did the idle jump or change any?
also try this
take your intake off [not your intake mani]
and start your car and cover the Throttle Body with your hand and if the car dies there is no vacuum leak but if the car doent stall/die then you have a leak somewhere
By 95civiceg
#132045 alrite ima try dat
hey um yesterday i notice my car was breathing hard from intake air filter
i took the intake off and then u can here the breathing coming from throttle body
#132052 idk wat that is mine does the same
#132054 do you have a bouncing idle? vac leak will cause that. Listen for a hissing. Did you do any work to the engine recently?
Look for cracked hoses, bad TB or IM gasket :thumb:
By 95civiceg
#132067 wat do u mean by bouncy
well my idle sits still wen i drive the car and come to a complete stop
my car idles drops to like 500rpm then goes up to 750-850rpm
#132070 he means the purgin idle that you get from a vaccum leak or a few other bad things
like bounces from 700-1500
By 95civiceg
#132072 no my idle is still
sumtimes it goes up and down but not that often
#132110 if you can't hear any hissing, and your idle isn't bouncing up and down, then what makes you think you have a vac leak?
Don't you have an IAT sensor missing on your car or was that a different motor? I'd start with the big problems that can cause your car to run poor, such as a missing sensor.
By 95civiceg
#132117 yup im missin the IAT sensor
