- Tue Nov 18, 2014 2:59 pm
#349929
rootbeer_eg wrote:The only strange thing is that they are 16s
Sometimes if you measure a wheel dia. from edge to edge, it will measure larger. Look for the size stampings on the wheel and go by those
Same for measuring width... the width is actually from one bead mounting surface to the other. If you measure outer edge to outer edge, the wheel is actually a little wider than the official width.
Also note they're 4x114.3, so they won't fit an EG without adapters or converting to 4x114.3
