- Sun Dec 28, 2014 1:59 am
#350601
Ive gone through and changed thermo switch , thermostat'. Checked the relay, bled the cooling system. And tested to make sure the fan motor still works. And the fan will still not come on by itself... the only thing I can think is that there is something wrong with the wires to the relay. So I was trying to figure out a simplified way to run new wires to everything and by pass the existing wires. Is there a way someone can simplify doing this for me and is it a bad idea?
- Sun Dec 28, 2014 11:54 pm
#350611
- Mon Dec 29, 2014 12:04 am
#350613
So you can get the fan to come on by running 12v straight from the battery and it has never worked on its own since you have owned the car? Is the car all stock?
- Mon Dec 29, 2014 1:07 pm
#350622
teal_dx wrote:So you can get the fan to come on by running 12v straight from the battery and it has never worked on its own since you have owned the car? Is the car all stock?.. that is correct. And all stock automatic sedan except someone put a crappy intake on it and removed the a/c compressor
- Mon Dec 29, 2014 1:41 pm
#350624
M, have you checked the fuse and the relay on the fise box under the hood.
Double check that. Also, have you jumped the coolant temp sensor to c if the fan turns on ? If the fan turn's on, then it would be that sensor. If the fan does not turn on , check also the ground feed that is near the passenger side headlight.
Double check that as well.
Let us know.
Let us know.
Drive it HARD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
viewtopic.php?t=28277
- Mon Dec 29, 2014 9:01 pm
#350644
Driv-it-hard wrote:M, have you checked the fuse and the relay on the fise box under the hood....yes I have already checked all of this..I just put a brand new sensor in ..the fan only still works when I jump it.
Let us know.
- Mon Dec 29, 2014 11:58 pm
#350651
U said they removed the ac did they also take off the 2 relays that sit next 2 the condenser
my shit is runing cuz of this forum
14#COUPE CREW MEMBER
my ricer coupe
http://civic-eg.com/viewtopic.php?p=260106#260106
my ricer coupe
- Tue Dec 30, 2014 2:34 am
#350654
Ill take pisc of mine 2 morrow so u can c if u have them
my ricer coupe
my ricer coupe
- Tue Dec 30, 2014 11:52 am
#350659
I just lookd up the 2 relays but it says one if for ac com and one is for the condenser fan
Ill get u a pic of thw wire diagram for the fan give me ur year make and modle and what country it was built
my ricer coupe
my ricer coupe
- Tue Dec 30, 2014 12:55 pm
#350660
elrompetoto wrote:I just lookd up the 2 relays but it says one if for ac com and one is for the condenser fan.. that fan does work when I click the climate control switch on..its a 95 lx sedan should be a us model
- Tue Dec 30, 2014 8:59 pm
#350666
Here u go here's the diagram
This is thw one with ac
This is the one for the cars that come with no ac
my ricer coupe
my ricer coupe
