ECU, Wiring, Sensors
By 94coupeturbo
#213609 B18A1
Arp Headstuds
Arp connecting rod bolts
Arp flywheel bolts
Stage 3 clutch 12 lb flywheel.
Cometic Headgasket .027
Walboro 255 fuel pump
440CC Injectors
Gates timing belt
T04E turbo
38mm wastegate
2.5 exhaust piping
stock pistons and rods
Nippon piston rings. 10 Psi on boost
AEM Wideband
Also would I need to run VAFC or not been told different things however I am not doing Vtec. So if you could help with that question to lol. Thanks
By 1995db7
#213610 after having your ecu chipped you won't need the vafc,also you might want to look into http://xenocron.com/ ,i get my stuff from them and are cheaper
By 94coupeturbo
#213799 Ok great just checking and all was unsure of ecu and good thing I did not buy vafc
