- Thu Jun 05, 2008 6:25 pm
#57617
After gutting your interior in your hatch, you probably noticed it looked like a mess. Wires & cables in the rear are ugly so here's how to hide them. No cutting or soldering needed!
First, what you have to begin with:
(The 2 unplugged harnesses in the pic are from the rear wiper motor that I removed)
Now lets tuck!
Unplug the big connector in the lower right of the pic.
Follow that harness around the driver side and back of the interior. It is held onto the chassis with plastic clips that usually break when you pull them out. Unplug any plugs (tail lights) and disconnect any chassis grounds along the way.
Remove the rear wing and unplug the 3rd brake light. Then push the plug & gromet through the hole in the glass.
Now lets tuck!
