- Sat Jul 06, 2013 2:32 am
#333918
If you have a broken gauge in your cluster and don't want to spend an arm and a leg for a used cluster, here's a great alternative. I picked up a auto dx cluster for $20. You can purchase individual gauges on ebay. Luckily the mileage isn't off too much between the two. Here's a comparison.
Uploaded with ImageShack.com
There's six tabs circled in yellow, press the tabs and remove the cover.
Next remove these screws circled in red.
Carefully lift the gauge you wish to replace. It comes strait out.
Repeat the first steps with your donor and carefully lower the working unit in place.
Replace the 3 screws and pop the clear cover back on. Enjoy your working cluster.
The hardest part about this was removing the hazard button and trim inside the car. Very simple. Hope this helps someone.
