- Thu Aug 05, 2010 11:14 am
#207523
My old mod
So, now we instal that center console from prelude 4th:
1. step:
Now we take it, and find correct position (P.S. try all gears)
2. step:
Check these angles, and cut as well burrow with dashboard:
3. step:
First that you can do, this fix first part (use screws, that i show second pic):
Next fix handbrake to the body.
1. step:
Handbrake fixing we need strong metal (i used 3mm metal, who name i don't know)
2. step:
Drill metal blade and screw with handbrake
3. step:
Drill two holes in metal blade.
4. step:
Now take right position and screw it with bolt whom show before.
Second connect handbrake with cables.
1. step:
From old handbrake take down metal who connect cables, and put on it.
2. step:
I don't know how to say that step, just do that who show in photo =)
3. step:
Round up that part who cut.
4. step:
Relax a bit, if you smoke, smoking some
5. step:
Use strong metal to connect handbrake with cables
6. step:
Now test, tight.
Collect all parts in car
1. step:
Connect armest to center console
2. step:
Don't forget lamps regulator
3. step:
Than you done, you must see that:
This is my friends interior:
That's it, thank for attention, i hope you understand me, because my english is broken =) If you see mistakes, please send me PM's with corrected, thanks.
1. step:
2. step:
3. step:
1. step:
2. step:
3. step:
4. step:
1. step:
2. step:
3. step:
4. step:
5. step:
6. step:
Now test, tight.
1. step:
2. step:
3. step:
