- Tue Mar 30, 2010 8:41 pm
#184663
If you mess up your car, it is your own fault. this is only a guide.
Things needed:
seafoam
bottle
you will be adding the seafoam to:
Engine: pour a third of seafoam in to the part where you put your oil.
Gas tank: add a third of seafoam into engine tank
Brake booster: feed the last thrid into the vaccuum feed. when doing this part, make sure you have someone giving the car some gas or else it will cut off. the car will choke a little bit.
When you finish feeding it into the vaccuum, turn the motor off for 10 minutes. After, turn it on and go around your neighborhood or streets to burn off the carbon. It's pretty cool. like a batman smoke screen.
It's also important to change your oil after you do this to get all the seafoam out of your car. Also, check your spark plugs.
Things needed:
seafoam
bottle
