- Wed Nov 26, 2008 12:16 pm
#80453
well as the title states my gauge cluster doesn't work. nothing, no speed RPM, gas and engine temp. not to mention my signals don't work. the hazards work fine tho. help please.
- Wed Nov 26, 2008 9:28 pm
#80544
blown fuse?
- Wed Nov 26, 2008 11:15 pm
#80561
Your cluster needs to work for the signals to work. Its all in one. The cluster its like a bridge. When connected it bridges the gap and makes contact. The sends the signal to the hazard button and from the hazard botton to the signal lights. That's why i dont know if anyone ever noticed this but if you have the hazard botton disconnected the signals won't work.
Did you check all your fuses?
You might want to check your hazard botton too. Might have gone bad aswell.
Also, another rare problem. The back up switch. Its wired to the same fuse. It probably has a short and its shorting everything out. Put it in reverse and have some one check it your back up lights are coming on.
Just a few ideas. Might want to check them all.
BoRIcuA y QUE!
k20fg2 wrote:wat about my signals?
BoRIcuA y QUE!
- Mon Dec 01, 2008 8:07 am
#81254
Ha! Never done that 1 b4 but coo. Fuck checking each fuse just change that whole fuse box lol
BoRIcuA y QUE!
k20fg2 wrote:ok so an update. i ended up changing the entire fuse box under the dash and everything works now. thanks everyone for the help.
BoRIcuA y QUE!
