- Wed May 21, 2008 9:57 pm
#56251
I'm going for a short block to do some work on within a short period of time, so now I have decisions to make.
Since I don't know everything, and lack experience in this field (newbe on 'building'), I'd like some advice.
Here's my situation;
My goal is a daily driver on the dark side, so boost, looking for a smooth and reliable ride, not a drag strip hero, but making nice numbers anyway.
And also, it has to be alive when not boosting, making it a nice, strong engine for (spirited) daily driving.
So my thoughts were with a B18C4 (B18C GSR) short block;
- install new ACL bearings,
- install new stock pistons and rings (maybe even JDM GSR pistons for a bit more compression?),
- have the crank balanced if necessary
- install new spec R oil and water pumps,
- Cometic head gasket (don't know what size though, .040 I guess?)
- ARP head and main bolts/studs,
- hone job, bore if necessary.
Head;
- slap on my B16A2 P30 head... off course with a few upgrades;
- Greddy or Toda timing belt,
- some work done to the head (mainly cleaning it up, regrind the valves in their seats, polishing the in/ex ports and comb. chamber),
- stock B16B or B18C (spec R) valve train
- AEM cam gears
I will install my P30 i/m and t/b, the 550cc RC's I have, and my PW:JDM i/m heatshield.
In time, I'll probably replace it with a Skunk2 PRO i/m and a tapered 70/72-to-68mm t/b.
But, atm I can get my hands on a newly AEBS sleeved B16A short block, 85mm bore.
Comes with a balanced LS crank and I believe with JE stroker pistons.
I have to get myself a set of Crower B17A rods, that would make 2.020cc of built VTEC madness.
This will cost a great deal of bigger bucks.
My fear is that the built B16 needs more aggressive mods to the head and intake to work properly, and will eventually make to much power for my needs, and not be a smooth engine I'm looking for.
My questions are;
am I right about the built B16?
if so, have I made the right choice for the GSR short block plans?
The sleeved B16;
http://members.chello.nl/m.sahin10/AEBS/DSC00931.JPG
http://members.chello.nl/m.sahin10/AEBS/DSC00929.JPG
http://members.chello.nl/m.sahin10/AEBS/DSC00930.JPG
Head;
- AEM cam gears
My questions are;
The sleeved B16;
