- Fri Jul 24, 2015 12:56 am
#354922
I plan on doing mini-me swap soon, while I have the head off I wanna replace the piston rings due to the fact I'm getting a lot of burn by. What piston rings should I get if I don't get the block honed? Is honing really necessary when it comes to this process? If so I think I might go with the idea of rebuilding my old block its a JDM d15 I'm sure. I heard these stock is a better approach then a d15b7/z6 mini me swap?
Without going into the whole long winded post I was going to make explaining your options here I'll just make it simple. When it comes to SOHCs don't rebuild them go online to somewhere reputable like Hmotorsonline and buy a replacement engine. It usually cost more to rebuild a SOHC correctly than replace it. The only reason in my opinion to rebuild a SOHC is if you are upgrading internal parts for performance reasons.
Also you can only determine if the engine needs honed once the head has been pulled off. On a high mileage old SOHC I'll safely guess that, yes, you will need honed. At this point you'd be pulling the block and disassembling everything because everything has to be completely cleaned after honing to avoid shavings getting into any important parts of your motor.
Reviving Classic, Crafting Culture.
Classic Honda apparel, prints, and digital downloads.
Instagram:
https://instagram.com/enjoymotorsports
Website:
https://enjoymotorsports.com
Instagram:
Website:
