B16, B18, B20
#35267 Not enough fuel. :wink:
#35286 did you upgrade your fuel pump when you did the swap?
By asianrob
#35287
D15kid wrote:did you upgrade your fuel pump when you did the swap?
dont need to upgrade fuel pump when using stock fuel pump
DC4rob wrote:dont need to upgrade fuel pump when using stock fuel pump
huh? :?
By asianrob
#35294 you said to upgrade the fuel pump and i said you dont have to because from factory they all are the same
#35296 but he did a b20 swap and wouldn't he need a better fuel pump for the increased engine size?
By asianrob
#35297 they push out the same amount of fuel on the CRV even if you had a CX one it still pushes out the same amount of fuel
#35298 ohhh ok
D15kid wrote:ohhh ok
good to know!
#35300 The key in this is that he has a B20 VTEC
Cx or CRV or whatever pump isnt gonna keep up with that.
By asianrob
#35315 we've always ran stock fuel pump on my bro's car (DX) with all the motors he had in it when we put the 255 walbro in that was a little much but and he had B20Vtec bored to 84.5 (running thin on stock sleeves) and cams p&p and it pulled very good but if you were to upgrade since staying NA 190 walbro should work just fine
By Macca
#35329 Explain how it lags like really really slow lag or build up lag or something ?
By asianrob
#35348 not enough oil pressure?
By split sec eg
#35366 yea jess got the fuel pump today 225 car runs strong vtec now lagg when it about to engaged but for a split second then it pulls hard???
