- Sat Mar 14, 2015 2:30 am
#352584
Hey guys I recently picked up a 1994 cx hatchback with a jdm h22a swap. I went to replace some broken wheel studs and came across a problem.
The drivers side axle is rubbing on the fork. You can see the ring line where it's hitting.
What can be causes of this?
One bit of info on the previous owner, he did everything as cheap and ghetto as possible.
This is the drivers side axle rub.
Passenger side looks to have a little clearance.
