By fago88
#318322 This weekend I started with stripping the car for the winter build :)
interiour out
reason for stripping the dashboard ... I hate pre-owners!
I really was wondering why the car is not burned down ^^
Everything out
staring wire tuck with the fuse box and engine harness on the left side
More updates soon :)
By fago88
#318447 did a good deal :D
used fc7:
after cleaning them
I want to switch from fork to eye... I think it's stable :)
And I go 1cm lower automatically
By fago88
#319060 started with painting my trunk after cleaning this mess up ^^
painted my rear strut
painted all and put everything together
New rear sleeves for the coilovers
this could get low :thumb:
finished my rear axle with new lca's
By TrailerTrash
#319123 awesome build :thumb:
By fago88
#319138 thx man! :thumb:
new stuff ... EP3 caliper and oil catch tank
and go on with the wire tuck :)
By JDMD15B
#319561 build looks amazing. i love the black and purple im doin my coupe flat black and purple. why the ep3 calipers?
By fago88
#319578
JDMD15B wrote:build looks amazing. i love the black and purple im doin my coupe flat black and purple. why the ep3 calipers?
why not? :-P
you can use EP3 calipers on the EG6 and DC2 axles in the front ;)
you have to use:
- EP3 caliper
- 300mm discs
- ep3 pads
I will show you when I get the disc and pads :)
By fago88
#319579 oh the pictures ^^
Ep3 caliper on vti axels:
also fits with 16" rims as you can see :-P
go on with the wire tuck:
finished :thumb:
and also got my new seats :thumb: :thumb: :thumb: :thumb:
By fago88
#319745 picked up my seats today :)
Tomorrow I will get my AP1 s2000 cluster and harness .... this will be a little bit work ^^
By fago88
#321407 renewed my EP3 calipers
and bought an s80 J4D LSD tranny and put it in with OEM Integra TypeR shifter and ES bushings
I started with wiring my S2K cluster, much easier than I thought!
I did a self made harness!
http://www.youtube.com/watch?v=ssNOIj1wtIE
Now I'm waiting for the converter to manage the signals and I need a cover for the cluster
By Ecc0
#321483 Know I've been away for a while but the progress on your build is amazing looking really good and loving the ep3 cali idea might have to start shopping for some myself. What 300mm discs are you using as ep3s are 5 stud???
By fago88
#321512
Ecc0 wrote:Know I've been away for a while but the progress on your build is amazing looking really good and loving the ep3 cali idea might have to start shopping for some myself. What 300mm discs are you using as ep3s are 5 stud???
you can use EP3 disks an drill new holes....what I do not prefer!
Or you can use some Fiat Coupe Turbo discs ...
specs:
4x98, 305mm disc and 59mm centering.... you have to edit them a little bit but I think thats better then drilling new holes :)
unfortunately the are no Discs with 4x100 300mm and 64,1mm centering
