- Thu Jun 07, 2012 4:14 am
#307581
dbrooks wrote:both of those headers will work.
They will both bolt up to the head, but they won't bolt up to the rest of his exhaust.
What I would do is first check to see if your mid pipe is the same length as one from a civic DX or Si. I think it will be. Then get the cat converter from one of those cars. Now you'll be ready to buy the header that you posted in your first link. Right now your car has the cat on the header instead of after, so the header on ebay won't be long enough because it is for the models with the cat after the header. Since the CX is the weakest motor of all the 92-95 civics, nobody makes performance parts that directly fit it. You'll beed to change your cat to a dx or si exhaust setup to get that header to work on your car.
So where the ebay listing says
Direct Bolt-On Installation, Requires NO Modification
that's only true if you have a d15b7 (dx or lx) or d16z6 (ex or si) not a direct bolt on for cx or vx owners.
And where it says
Increase High Flow Air, Instantly Gain 10 -15 Hp. / Tq.
is a load of BS. You'll be lucky to get any additional power out of a D15b8. The header will probably reduce your back pressure which may cost you low end power.
My 1992 SOHC Turbo HatchMy Youtube Channel: 6th Gear Garage
