- Fri Nov 18, 2011 12:25 pm
#281939
I did a
http://www.theretrofitsource.com EG6 Bi-Xenon HID projector swap. Its really not that bad at all if you buy the morimotto D2S Mini H4 Projectors. They are literally like plug and play once you remove the glass from the headlight housing.
I bought some SPEC-D headlights with black housing, removed the glass by baking the headlight to soften the seal. Then remove the hardware inside and screw in the H4 projector. I even put in some LED city lights
The only tricky part is to make sure you align them right, and that was also easy because these D2S projectors screw in so nicely. No gluing like many other people end up having to do for projectors such as the FXR's.
Over all project cost after shipping was about $330. I recommend it, it was money well spent!! Thses projectors are very bright!! and extend so far!
Here are some pics:
from ebay
Just needed to add the shourds to cover the hardware and make it look more clean
shrouds are in this picture, not the best picture but it was all I have atm lol
these are OEM white 4300K Bulbs but since they are TSX/RDX like replicas, they have that color change when your lights flicker up and down bumps.
