- Thu Oct 20, 2011 8:59 pm
#278471
i wanna do a five lug conversion and i was wondering if i can use the CRV ex rear and the prelude front beaks thanks
- Fri Oct 21, 2011 12:32 am
#278497
they will not just bolt up. Someone on here mentioned something about it being possible with modding. however its not a 30min-1hr job using just unbolts and bolts up.
- Sun Nov 06, 2011 6:30 pm
#280457
no to thread jack....but would be possible to use the 06 civic front and rear hubs in the 92-95 civic spindles? and then just buy the rotors and calipers?
what is the proper way or easiest way to do a 5 lug conversion?
95 Civic Coupe Ex D16z6 Vtec
79 Pontiac Firebird Esprit
73 K5 Blazer Big Block on 40's
- Mon Nov 07, 2011 11:06 pm
#280631
those from 06+ are different style spindle.
You CAN use the CRV knucles. with your A arms. being that they are (From what i did my research on) the same as the JDM DC2 front knuckles.
BUT WITH THAT IN MIND!! you will have to use the 36MM outer CV to fit in the knuckles.
or your can use your EXISTING EX knuckles or integra knuckles. ( or and ABS knuckles will work too) and order the Type R hubs and press them in. and as far as the brake calipers go.
Prelude Vtec, Odessey ( i think 92-97? that body style), Legend, are the same as the Type R calipers.
you will probably need to use the 23T bracket to bolt them on ot the integra/civic hubs.
you can also use the Legend GS ( the 2 piston caliper but thats a little more pricey)
and the NSX caliper too.
as far as wheel bearings go. the CRV and the JDM ITR are( should be ) the same part number.
but if your going with the USDM ITR hubs then the bigger Wheel bearing should be fine ( the ones for the ABS/EX civics and integras)
95cpeEX wrote:no to thread jack....but would be possible to use the 06 civic front and rear hubs in the 92-95 civic spindles? and then just buy the rotors and calipers?
92 civic cx sold!!
white 92 civic Si (traded)
primered 94 teg sold
92 civic DX sold!!
93 red EX coupe parted out!
92 civic LX sold!!
90 240sx sold!
93 faded black EX coupe
92 civic DX sold!!
92 civic LX sold!!
90 240sx sold!
- Thu Nov 10, 2011 4:55 pm
#280987
What is a 23T bracket from?
- Fri Nov 11, 2011 12:44 am
#281036
the 23T is off of Integra type R
WhiteEGh23 wrote:What is a 23T bracket from?
92 civic cx sold!!
92 civic DX sold!!
92 civic LX sold!!
90 240sx sold!
92 civic DX sold!!
92 civic LX sold!!
90 240sx sold!
- Fri Nov 11, 2011 2:11 am
#281047
my brain hurts
good info!
asianrob wrote:95cpeEX wrote:no to thread jack....but would be possible to use the 06 civic front and rear hubs in the 92-95 civic spindles? and then just buy the rotors and calipers?
my brain hurts
good info!
- Fri Nov 11, 2011 10:32 pm
#281131
lol thats just part of it just dont realize there so much inter change able parts when brakes and suspension goes.
the rears are a little more surprising ! lol
94_jdm_ferio wrote:
my brain hurts![]()
good info!
92 civic cx sold!!
92 civic DX sold!!
92 civic LX sold!!
90 240sx sold!
92 civic DX sold!!
92 civic LX sold!!
90 240sx sold!
