By asianrob
#275000
cody27 wrote:
asianrob wrote:it should be prewired for it. just thro and LED in there lol
i figured that as well considering damn near everything else has a plug but i searched when i put in rear speakers and all i could find was the speaker plugs, however its not hard to run a hot wire and a ground with a switch which is what i will eventually do as i have a 24" LED bar that i had in the trunk of my VW....kinda rice but it works
in the spot where the light plugs into should be a plug taped up in there. stick your finger in the hole and kinda wiggle it around.
i know that sounds dirty
By cody27
#275177
i had the whole rear deck off when i put in speakers and no plug, i dont think any of the coupes had trunk lights... now that i think of it i dont think ive seen any sedans at the wrecker with em either which would explain the lack of plug cause ive added a clock, a cluster W/ tach and the rear speakers all of which had plugs where they would be
only thing i can think of with trunk lights is the HB cause they have plastic panels in the trunk and the light is in one of the panels.
By asianrob
#275235
mine had both my sedan LX and EX coupe had wiring for it.
you need to look from the trunk inward. its not going to be under the rear speaker cover area.
just a sample pic but its in there. facing that way. you will have to dig a little for it.
By cody27
#275310 well damn i guess im gunna have to go look harder than, in which case tha makes things even easier to wire it up
By Stank.EG6.Stay.Nasty
#275320 Thats cool i gotta see if i got that...
By cody27
#275360
RWMIII wrote:
oses21 wrote:anybody find one on a dx??
My DX coupe did not have it prewired.
have not rechecked mine yet but if that is the case that would make sense why i didnt find it
By asianrob
#275715
hmm that sucks
i think there is a write up on how to wire it up (Its on a hatch but the concept is the same. )
By gummer
#275718 you could run a fused hot wire to the trunk and use the ground from the trunk latch, it has a wire that sends the signal to the cluster for an open trunk, by this way the light on the trunk will turn on each time you open the trunk
By cody27
#275719 in the case that its not prewired ill just do as i planned to in the first place, run a fused hot wire from the fuse block and the LED tube i have has a 3way switch off/on/ricey blink mode
By cody27
#275819 well ill be damned http://www.used-oem.com/servlet/the-614/92-dsh-95-CiViC-*-Coupe/Detail
still havent found mine though i gotta get in there with a flash light and find it cause there definitely looks to be a hole for it as was posted in the picture above
but according to this thread DX/CX never came wired for em so that would explain the lack of plug http://honda-tech.com/showthread.php?t=2957294
