By FunctionX
#270454 Hey all, I'm planning to buy a socket and wrench set and was wondering what size would I be needing to work on my car.
rtegra92 wrote:metric,
if you can get a set that ranges from 8mm to 19mm
common honda sizes 8 10 12 14 17 19
3/8 drive is fine
x2
Those are pretty much all you need.
Only odd ball i found was the Rod bolts and a b16 were 13mm,
By Stank.EG6.Stay.Nasty
#270473
3/8 drive is fine
:headbang: also 18mm - at least 26mm for the bigger nuts like the axle nut... 1/2 dr. would be better seeing that our cars are old and bolts are a BISH to get out.
By Flatland_EG
#270477 Might I also suggest eventually picking up a set of stubby box end wrenches and ratcheting box end wrenches. They are a little more on the expensive side, especially the ratcheting wrenches, but they work great for hard to reach or tight areas.
Oh, and definitely some extensions and a breaker bar.
#270502
EGg OH! wrote:Might I also suggest eventually picking up a set of stubby box end wrenches and ratcheting box end wrenches. They are a little more on the expensive side, especially the ratcheting wrenches, but they work great for hard to reach or tight areas.
BREAKER BAR! :woot2:
By TrailerTrash
#270509
3/8 drive is fine
if your axle nuts are as stubborn as mine were your going to need a 1 inch drive :thumb:
#270520
3/8 drive is fine
[smilie=BangHead.gif] AXLE NUTS!!
By FunctionX
#270654 Alright, cool. Well for now I bought me a stanley 85 pcs tool set and a Duralast 11 pcs metric wrench set from autozone. :D
By cjw_89
#270667 axle nut is 32mm btw 8) on 92-00 94-01 civic/teg it is anyways lol
By RWMIII
#270686 Dont forget the crank pulley tool (yes, there are other ways to remove it, but save yourself the headache):
By ccornewell
#270737 Dont forget the cheater bars. My fave is a jack handle from a 4 ton floor jack. It makes my 1/2 in. breaker bar pull its weight :thumb: . also, screwdrivers are not prybars!
#270738
FunctionX wrote:Alright, cool. Well for now I bought me a stanley 85 pcs tool set and a Duralast 11 pcs metric wrench set from autozone. :D
i wouldnt have went with duralast man.. snap-on, blue point, or craftsman... Better quality and they have a wide selection
By FunctionX
#270830
hahaha, i would have went with snap-on or craftsman but then are pretty pricey for my budget at the moment. I'll get them when I get my own place and a garage to work on my car :hehe:
#270854
no doubt man :thumb:
