- Sat Jan 15, 2011 11:28 pm
#233533
Manifolds you should really just use the manifold that came with it if you have room for it.. and tb's k tuned makes adapter plates so you can turn a drive by wire engine into a throttle cable engine as far as tb goes....
K parts are expensive and if u shell out the cash for it you will be happier in the long run....
If I remember right you can take the rocker assembly out of a real vtec k head and cams too.. use a kpro... and throw them into the ep3 k engine and people's r making 200whp on that alone... u can use a type s ecu as well it will run a lil rich though...
U want the injectors from the real vtec head as well because there is a 40cc to 60cc difference between injectors for the k engines
Just and idea for ya....
And check out k20a.org for k questions there are a lot of people who have tested this sh!t out already
"smoke me a kipper ill be back before breakfast" - ace rimmer
