ECU, Wiring, Sensors
By NOCLUE
#221092 Im at a light car shuts off, not my lights just motor, turn on my blinkers push it to the side pop the hood everything looks good, crank it turns on fine, drive about seven miles to a buddys house fine, drive about 12 miles home fine, NEXTDAY go to the store runin like a champ back home went out that night on the way home cruiseing in 4th shuts off, takes a few trys i let it sit try again cranks, get home read the code a code 41 and 15, i have not had a o2 in 4ever, thier is a bolt that came with the header in place of the o2 but the 15 is new to me, never seen it (ignition output signal) i crank it today code 15 is not poping up only the 41 (normal) but the car does not crank every time and some times shuts off but some times does crank and run idle fine. wtH!!!
By Benj
#221106 pull the cap look at the part that touches the coil.... whine and bitch cuz you now have to probably spend 100 bucks on a new coil and another 30 to 40 for a cap. gl
