ECU, Wiring, Sensors
By drew_ej2_owner
#218892 ok guys i took the clock out not too long ago to have it glow red n i put it back in and everythin was good.. but a couple of days ago it stopped coming on, what could this be?
By newbie101
#218893 Could be the ground behind the dash cluster. Mine is loose (I think) and it seems to mess all that stuff up. I would check that first since it used to work but now it doesn't. I don't remember if there is a separate fuse for that or not. . . does anything else not work?
By drew_ej2_owner
#220055
newbie101 wrote:Could be the ground behind the dash cluster. Mine is loose (I think) and it seems to mess all that stuff up. I would check that first since it used to work but now it doesn't. I don't remember if there is a separate fuse for that or not. . . does anything else not work?
uhmm not to my knowledge.. my cluster woorks fine n i believe my hazardz too
#220069 put it in a friends eg, it dont matter wat model and if it works then someting is wrong wit ur wiring, if it doesnt then the clock is bad
my Dash ground was unhooked and the cluster worked just fine. I dont recall if the clock had issues but I know I when I turned off the car the radio would be on for 2-3 seconds afterwords. When I pluged it back in all my strange issues went away.
