- Tue Sep 14, 2010 5:34 pm#213639
Small update:
Ordered this UltraRacing lower bar a while ago and it arrived the other day so managed to fit it. It took a while as it was super tight.
Also got a new gear knob from JAE:
Tegiwa Ball
- Thu Sep 16, 2010 5:01 pm#213995
I was bored with my dash so did a little experiment:
I went crazy with a load of skate stickers on my glovebox
I still need to find a place to hide my ecu and fuse box.
- Fri Sep 17, 2010 7:51 am#214134
why not use the original place for your ecu?? and if you remove your glove box will the fuse box not fit in that empty space behind there?
- Fri Sep 17, 2010 10:22 am#214150
The ecu wont fit with the jumper harness on it and i think i may be able to squeeze the fuse box behind the glove box, but it will be tight.
- Wed Sep 22, 2010 6:54 pm#214971
I stripped out the sound proofing from the rear of the car guess its a small weight saving 2.5kg Im going to clean it up and give it some fresh paint.
This is how it stands at the moment:
- Sun Sep 26, 2010 1:26 am#215429
Loving everything about your hatch man, it's super clean! The only thing buggin' me is that tacky gas cover, but hey... to each their own!
