ECU, Wiring, Sensors
By 92dxeg
#189367 what ecu do i use for obd2 b20
By JUICE
#189373 not sure what ECU it is but, I'd imagine most of those would be AUTO and would need modified anyway. Just get another ECU (get a cheapy like a DX P07 or whatever) and get it chipped with a basemap for that motor
By 92dxeg
#189378 well it is obd1 but he wants to go to obd2 to pass NJ inspection cuz its a 99 teg would a ctr ecu work
By forcefedEG
#189507 use the ls ecu... i had a 94 teg and ran my b20 off the stock p75 and it ran fine... it should work to pass your emissions, id use the ls comp over the ctr for that engine...
forcefedEG wrote:use the ls ecu... i had a 94 teg and ran my b20 off the stock p75 and it ran fine... it should work to pass your emissions, id use the ls comp over the ctr for that engine...
x2
My B20 Ek Ran off OBD1 P75 LS ECU and ran amazingly. :thumb:
By 92dxeg
#189766 but it is going to throw the vtec code. also i have an obd2 gsr ecu will this work???
92dxeg wrote:but it is going to throw the vtec code. also i have an obd2 gsr ecu will this work???
gsr ecu will run a stock b20 very badly. The fuel/spark maps are totally different. The LS ECU doesn't look for vtec so wont be throwing a code. It also has correct spark/fuel maps and runs amazing. I pulled a B16 and dropped a JDM 99spec b20b in its place, same wiring harness everything, put in an obd2b to obd1 adapter and a obd1 p75 ls ecu and it ran perfectly. It would push you back into your seat, it's awesome. <3 B20's
OBD 2 ecu's wont plug into an OBD1 car, they also dont make adapters to go that route, you can go FROM OBD2a(96-98) or OBD2b(99-01) to OBD1(90-95). Never the other way around.
By forcefedEG
#190129
x2 LS ecu will not throw a light on a b20 for vtec... as an ls is not a factory vtec engine...
