- Sun Dec 06, 2009 10:54 pm
#160289
i have a 94 dx coupe i have a hydro trans d16z6 running on a po6 ecu vtec not hooked up until i put in my p28,,, anyways im having a problem with it no matter what the rpms cant be lowered past 2k. only mods i have done to the car are-
Replaced oily air intake
changed the oil
changed the oil pan gasket
installed a k&n oil filter
changed the valve cover gasket
changed the spark plug gasket
also when i rev the car sometimes it acts like its not getting gas,this all happened after i changed the oil pan seal and oil also when i start my car it sounds as if i have a stage 3 cam in it. maybe its off timing? today when i drove it home from work i pressed on the brake and it killed my engine.i have also recently noticed that my heater hose under my dizzy is spiiting out hot water...i know i have asked a lot of questions if anyone has any free time i could use some answers thanks
changed the oil
