- Mon Jul 30, 2007 1:40 am
#17793
built-EGy8 wrote:Ive got my MAP all ready to be pinned but I have a little problem. There are 3 wires comming off of my MAP sensor. GRN/WHT,YLW/RED,andSolid WHT. which is pinned where in my harness?
Ok got it...
Green/White wire from the MAP sensor should change to Green/Blue after the main harness plug, and then goes to pin C11 on the P28
Yellow/Red wire from the MAP sensor should change to Yellow/Green after the main harness plug, and then goes to pin C10 on the P28
Solid White wire from the MAP sensor should change to Pink/White (93-95) or White (92) after the main harness plug, and then goes to pin C9 on the P28
My 1992 SOHC Turbo HatchMy Youtube Channel: 6th Gear Garage
