By Mat<3JDM*
#162339 Hi My buddy want to sell me his suspension Civic Sir 2000 Ek oem shock whit skunk2 coil but I dont know if it will fit my eg coupe can you help me !!
tanks
By Classiccarsrule85
#162345 ok im pretty certain at least the springs or coilovers will transfer over the suspension however ....
i know the ek civicshave a different set up for the upper control arm where it bolts up to the side instead of the top not sure if you could change that but the shocks should work and even if the mount part dosent look right you can always transfer your mounts over to the shock part itself since the shock is basic im pretty sure at the rear end as well it should be the same so anyhow in quickness here
shocks and struts should be good
really anything else besides teh lower control arms in the rear since im not sure if those would work shouldnt be used...
not completely a 100% positive but close to it
#162691 front springs/coilovers will swap with out problem.
Rear springs/coilovers will swap with out problem.
Front strut/shock will swap with out problem.
Rear strut/shock will NOT swap with out problem. - Reason - The EK rear lower control arm uses a thinner bushing than the EG. Not worth modding to fit. Just use your current strut/shock.
Hope that helps.
By Mat<3JDM*
#163537 tanks it will be all right with your help !!
