Appearance, Paint & Body Work
By Nitto_408
#152983 damm this is impressive
eventually i wanna do this :)
i think the wiring part is gonna be a BITCH :/
is ur dashboard in?
Kane wrote:
but.. how easy is it to access the wires if you needed to change something?
wire tucks are not for the indecisive :D
I had to change distributors and it wasn't too bad... as long as there's no major change to the setup, you won't need to get back into the harness.
Nitto_408 wrote:is ur dashboard in?
Yep dash is back in. I have to put in the upper and lower center console though... so there's some visible wires below the radio area.
By ALPHAMALE
#190878 well now i used the old srs box for the fuse box. its a great central location. it will also help. since i wont have that much of a dash lol. looks very good. I'm going to be using the plugs for the fire wall instead. i have a few holes left open so i can finish my tuck but i shaved a 97% of all the holes. for the brake lines i was going to use ss braided lines? how hard is it to work with the hard line?
By dimensia
#217765 Looks Awesome..Nice Job Duds !! :woot:
By MHG
#229027 Goddamn!! :thumb: I have one question, where did you put the wiper fluid reservoir?
By illason
#243836 I am doing this now...well I am trying. I think I just messed up my hatch I'm not sure what I am doing. I took mostly everything out of the bay and I'm not sure how to put things back together. I have read this forum like 5 times.lol
illason wrote:I am doing this now...well I am trying. I think I just messed up my hatch I'm not sure what I am doing. I took mostly everything out of the bay and I'm not sure how to put things back together. I have read this forum like 5 times.lol
Yeah this is kind of difficult to do, so I wouldn't attempt if it sounds hard. And take a ton of pics as you go so you can look back at the pics to see how things were. If you've never worked on wiring harnesses or installed a stereo before then don't even think about doing a wire tuck. :death:
By illason
#243919 damn too late....my car is trashed now. anybody wanna buy a shell?
By billllll23
#246560 u know u can turn the inlet on the manifold don to hide the booster hose right .look cleaner even more :)
By bserius
#250779 looks sick man. i wanna shave my bay, build motor, and get a chase bays harness for my hatch next year if i can
By tonyjdm
#251148 Image
i do the same relocation, but many people told me that the tank don't work if putted in lower position than the radiator cap... :?
By tonyjdm
#251525 nobody knows?
