ECU, Wiring, Sensors
By turtlespeed37
#129872 ok so i had this guy put a d16y7 into my 94 civic dx so he converted it to obd1 and i have a idle problem a year later and it just gets worse. ive checked almost everything. now i want to make sure that the wiring is done right. the guy cut every wire and connected it to the wire in the ecu instead or using a jumper harness so now im trying to find the information to check it. if you can help feel free to reply. i have p06 running it if that helps
By suspendedHatch
#129882 Yeah unfortunately an OBD1 ECU will never idle an OBD2 D series quite right. Just check the ECU for codes and do the regular idle fixes and if that doesn't improve anything then you're pretty much stuck with what you got.
By turtlespeed37
#140891 Fixed :woot: it was a bad fast idle control valve.about time to :woot:
