In Car Entertainment & Security
By pedroa06
#124248 this is what i have.. i got the hook up and picked it up for 60 with box okay for me..
http://www.onlinecarstereo.com/CarAudio ... ctID=15650
what amp will make this hit the best..?
i want the most i can out of this single 10"
i dont want to put 2 12"s to big of a box..
By pedroa06
#124327 kool thanks ima look into that today later..
rite now i got to take care of fathers day business i bought him
2 of these
http://www.millionbuy.net/CarAudio/Subw ... ANI-S3F-12
hes not all that into audio he just wants clean bass..
so what amp will handle 2 of these..?
thanks alot i really appreciate u helping as you can see im a noob at car audio.. lolz
By 92egdxhatch
#124329 for those get a 2 channel amp that pushes 300 watts RMS, alot of people dont realize it but the RMS rating is more important that peak power rating, make sure you get a get wiring kit, good wiring makes a big difference in a system's sound
By pedroa06
#124426 alrite so for the 2 12"s get a 2 channel 300watt amp and for the 1 10" get a 150 watt amp right?
By 92egdxhatch
#124431 well almost, the RMS is the continuous power the sub can take, for your 1 10 you can get a 300 watt amp that pushes 150 watts RMS (continuously)
this shit can be really confusing :wink:
By egsedanguy
#124433 match the rms from a amp to the rms on the sub. if you sub need 150amps to push then by a amp that is 200 amps. better to have more power than not enoug. i hate when someone get a amp thats to small and had evry gage maxed out. my amp is plenty of power for 2 subs. and the amp is only up like 1/2 -3/4 of the way. also use a mono block amp. its designed for bass. also need somthing with a goo ohm rating. like 2ohm stable. then if your subs are good you can bridge it for a lil extra bump. get dual voice coil subs. they have a wider range of bass. go to a good shop and jest let them know what your looking for. the combos of base and amp setups is endless.
By egsedanguy
#124435
92egdxhatch wrote:well almost, the RMS is the continuous power the sub can take, for your 1 10 you can get a 300 watt amp that pushes 150 watts RMS (continuously)
X2. :lol:
By 92egdxhatch
#124437
egsedanguy wrote:match the rms from a amp to the rms on the sub. if you sub need 150amps to push then by a amp that is 200 amps. better to have more power than not enoug. i hate when someone get a amp thats to small and had evry gage maxed out. my amp is plenty of power for 2 subs. and the amp is only up like 1/2 -3/4 of the way. also use a mono block amp. its designed for bass. also need somthing with a goo ohm rating. like 2ohm stable. then if your subs are good you can bridge it for a lil extra bump. get dual voice coil subs. they have a wider range of bass. go to a good shop and jest let them know what your looking for. the combos of base and amp setups is endless.
x2 easiest way to look at it
By pedroa06
#124442 alrite thanks so one last questions since i have two of those almanis 12"s do i add up the rms on the subs and find a amp thatll match the closest or i dont add them up?
yeah this shit is a bit confusing but if i go o a shop not knowing anything i buy a bunch of worthless stuff that i dont even need hahah.. :lol:
By 92egdxhatch
#124447 no u dont add them up, the amp will push them both
By pedroa06
#124449 ok thanks so ima go pick up a 200 amp for the 10 and a 400 watt 2 channel for the 2 12"..
correct me if im wrong..?
By pedroa06
#124453 alrite kool thanks alot guys ill let u know how they hit once there in...
:thumb:
By egsedanguy
#124461 just make sure they are mono block. dont use amps that are for you highs. ya it will work but not that good. bridge the 12in subs off the 2 chanel. you will get more ohms. also pick up a adio book that tells you waht everything means. it will asist you in making the right dessisions,
