- Fri May 01, 2009 3:13 pm
#114342
hey guys im new here and im from the u.k, was wondering whats the easiest civic to drop a b16 into as im planning on doing this very soon have a 1.3 dx and a eg esi both stock thanks in advance, nathan.
- Fri May 01, 2009 4:58 pm
#114359
Any 92-95 Civic will be an easy swap.
However all 92 Civics are wired for VTEC so that makes wiring easier.
All 92-95 Civic EX(usdm, Came with D16z6 SOHC VTEC) and VX(USDM Came with D15z1 SOHC VTEC-E) are wired up for Vtec. Pretty sure the UK Got similar Models. not sure what there are called. Our UK Members will fill you for sure though.
No matter what 92-95 Civic you drop it into. You will still need to run the Knock sensor Wire or have it disable via tuning.
