By 1sicksi
#117327 ok i have a 92 si hacth...it does not have a rear sway bar.dont ask way.i dont kown if it came with 1....i have a rear sway bar off a 91 teg well this work? and were does it bolt to? pics wound help! and if that does not work. what well? :thumb:
By dawg316
#117348 your best bet would be to take one off a eg sedan. they came with rear sway bars ( i believe so ) you can probably modify the integra one but if you want a decent rear sway go get a sedan one from the junkyard.
By 1sicksi
#117362 just 1 person..come on
By Mr. Pink
#117403 the person that replyed is not 100%. The only sedans that have a rear swaybar are the ones with ABS. the DX does not come with one from the factory. same goes for the coupe i believe.
#117439 Any sway bar from an integra/civic will work. You wil need LCAs with mounting holes for the end links. if you get a ITR sway bar you will need a reinforment for the subframe. ASR makes a good one.
By BLaCkSiLo
#117715
Greasedmonkey wrote:Any sway bar from an integra/civic will work. You wil need LCAs with mounting holes for the end links. if you get a ITR sway bar you will need a reinforment for the subframe. ASR makes a good one.
x2 on the ASR brace, only the 4-DR USDM EX models came with rear discs, ABS and rear sway bars... i believe they are only 11 or 13mm tho which isn't very impressive
By asianrob
#117810 the sway bar for the 90-93 integra will not work. but the control arms will.
i know this for a fact.
thats un true.. i had a civic LX-Abs and it had a rear sway bar and rear discs same as the EX.
By BLaCkSiLo
#117854
DC4rob wrote:the sway bar for the 90-93 integra will not work. but the control arms will.
oh really? well then, i was under the impression that only the EX's did... you probably had a canadian model? :eh:
#117878 sedans with abs got the discs and sway bar.
