B16, B18, B20
By CaliEJ2
#106941 mine isnt kicking in either but its giving me CEL code 17 (VSS). I read somewhere that if the VSS is not working properly, vtec wont kick in. Im not 100% sure but it cold be the VSS. somebody correct me if im wrong :?
#106980 yes, it could be the reason.
DuhQbnSiLo wrote:damn going to have to take out my dash >_<
whoa, hold on. I dont see why you need to take out your dash.
The Speed Sensor(VSS) is located toward the rear of your transmission. If its a VSS issue causing vtec to not hit it would be here. not under your dash.
By CaliEJ2
#107044 why wouldnt vtec work if the vss is malfunctioning? :?
CaliEJ2 wrote:why wouldnt vtec work if the vss is malfunctioning? :?
in order for VTEC to engauge quite a few conditions have to be met. One of them is a VSS signal. If the ecu doesn't know how fast its going it wont crack vtec. Just like it wont crack vtec if it doesn't know oil pressure.
By DuhQbnSiLo
#107058
ima see 2morrow
