- Sat Mar 28, 2009 1:16 pm
#106261
Started work on the radiator setup, bought a Koyo EP3 radiator and started fitting that into the new front subframe, unfortunately there is little left of the original subframe to make the radiator fit snuggly. Took 1 pic before I started, will post the rest when I get to it.
Also started with the brake setup, chosen for Wilwood Superlite 6-piston to fit the 298 x 32 mm disc.
I have this thing figured out so that I do not have to give in to much offset to both clear the lower arm joint/bolt from the disc and clear the caliper with the high offset ITR wheels...I think I will end up with an ET of around +45~+43 when I'm done to meet the clearances.The ITR is +50.
Please don't mind the rotation direction of the caliper, This is just fitment..
The disc and caliper:
Fitted on the car:
Also finished mocking up the complete rear, calipers completely rebuilt, new EP3 discs, new parking brake cables, toe-links installed etc etc
