- Wed Mar 18, 2009 9:43 pm
#104192
Yep, my radio and digital clock on the dash has no power running to them, any ideas of whats wrong?
Yes, I checked the fuses.
Classiccarsrule85 wrote:did you check the plugs on the fuse box i know in that harness there are 2 plugs going to the fuse box....besides that is your cluster n all that working? thats all one semi easy to remove harness not sure if its the harness tho....
dawg316 wrote:check underhood fused labeled ECU backup or something like that. my friend had a similar problem and that fixed it
