B16, B18, B20
By berg89
#205431 Well my roommate has a 92 Acura integra. An my prob is that when Im taking it through its gears it kinda bogs out an stops accelerating around 3 thousand then kicks back around four. My question is, why is that an how can i fix it? A little info on the motor, its a b18a1 An is completly rebuilt for turbo. But still n/a for now. Any help will be great. Thanks
By civicboy18
#205552 have you double check the ecu wring connections? or like metioned above, does it flash the CEL? :)
By itCouldgeTwoRse
#205555 assuming that the car hasnt really been modded or torn apart make sure that the light actually works. some people pull the bulb to make you think its not on.
so key over the ignition and see if it pops on for a second. if not theres prolly a cel.
get a bulb and stick it in there then i beleive its by the ecu where you car use a paper clip to jump the connection and the check light will blink your code.
since its obd1 you cant just look at the little blinky light like obd0 :( :thumb:
By berg89
#205574 No codes. Thats another reason im asking.
An its obd0.
By berg89
#205673 This car is a early 92 an its a obd0. To prove it, the ecu has the light in it. I just dont know why it would do that an throw no codes.
#205725 get some pics of the bay, and what ecu is on the car?
By berg89
#205730 I have no idea what ecu it is. Its all stock. Im not going to be able to get a pic of the the bay for awhile. My roommate took off out of state. Any suggestions of what i should check out when he gets back?
