- Tue May 04, 2010 12:43 pm
#191746
yes sir, mine is a bone stock usdm gsr bottom end 95 spec, with a 2000 si head, mild port job, i had the valves re-surfaced, i used the gsr cams, and arp head studs, and everything else is stock, intake manifold, throttle body, injectors, everythings stock... when i had that engine in the car i have the turbo on now, i had that enigne, with a dc ITR replica header ande a stg 2 clutch and a gsr trans, it ran very good and pulled very hard, i out ran a dyno tuned z6 on like 9psi, i also had my chipped p28 behind it then,
now i have it in my dd with a stock clutch, LS grears and a gsr ecu and a 4to2to1 header.... but it still runs great...
PANDA CREW No.20
