- Tue Mar 30, 2010 11:28 pm
#184687
I got a gsr motor in my hatch. I just had the bottom end rebuilt in April of '08. Today i tested my new compression tester out and got a reading of
1-205 psi 2- 155 ish 3- 170ish 4- 200ish
I was told that a head gasket could cause compression test numbers to be very down. Is this my problem? The car runs fine until i pop vtec then it gets hot sometimes. It also blows coolant back into the resevoir when i beat on it a little bit. I am going to replace the head gasket either way. But would the head gasket cause low compression numbers?
Fox Tuning
'95 Civic CX with Goodies!
